You are here: PSPad forum > English discussion forum > Re: Real tabs not working
Posted by: ucavus | Date: 2016-01-19 01:34 | IP: IP Logged
Thank you so much, Jan. Real Tabs are back to normal.
Posted by: cebe_tolosa | Date: 2016-02-02 09:44 | IP: IP Logged
pspad:It should be fixed in the current 4.6.1 (2707) build. Available in the developer forum.
I will be glad if somebody can confirm it.
i had the problem with real tabs not working.
It's now OK with the 4.6.1 (2707) version.
Thank you
Posted by: Aguilucho | Date: 2017-03-29 22:35 | IP: IP Logged
Hi: Im new to the forum but I use PsPad for years
My Real tabs not working either.
I followed all your instructions, uninstalling and then reinstalling as administrator (no portable), I set settings for Real Tabs checkbox but
nothing...
when I press Tab key, appears spaces instead of real tab
Any advice?
(win7 sp2 32bit)
Posted by: Aguilucho | Date: 2017-03-29 23:19 | IP: IP Logged
Sorry, I forgot that I have the problem with installed today (March 29) PsPad 4.6.2 (2750), newer than fixed buids mentioned in this thread before...
Thanks for the time when PsPad worked fine!
