You are here: PSPad forum > English discussion forum > Re: Can't save ftp connection settings
Posted by: jevpots | Date: 2015-10-09 11:36 | IP: IP Logged
Must be doing something stupid but can't find my way through. Grateful for any help.
Been using PsPad for years. Recently had to rebuild PC and let it install Windows 10. Installed PsPAd 4.6 and then tried to reset my ftp connection.
The problem is when I click on 'New Connection' and then input the settings and click 'OK' nothing is saved but the connection name (xxxx) does appear in the listing. CLicking on it to connect brings up the error message 'xxxx does not exist'
Any help appreciated
Posted by: pspad | Date: 2015-10-09 11:54 | IP: IP Logged
For Windows 7 and newer
Please ensure that you don't install PSPad as portable. No application has rights to write into Program files folder.
You have 2 ways how to fix it:
1. Run PSPad installer again and uncheck option "Portable application" during setup.
2. Run PSPad as administrator (use right mouse) to elevate PSpad rights, go to Program settings/System and check Multiuser environment
Your previous setting will be preserverd.
Posted by: jevpots | Date: 2015-10-09 19:54 | IP: IP Logged
Many thanks - running as administrator fixed it
