You are here: PSPad forum > English discussion forum > Position of Right Edge !
Posted by: pythonui | Date: 2015-07-30 05:55 | IP: IP Logged
Is there any possibility to have position of right edge language specific?
i.e In python we do required at 79,in Qbasic at 100...like that
Thanks
Posted by: pythonui | Date: 2015-08-03 11:17 | IP: IP Logged
Is this possible or not? or any alternative for same?
Posted by: pspad | Date: 2015-08-03 11:55 | IP: IP Logged
It's not possible now. I can add it as part of highlighter settings
Posted by: pythonui | Date: 2015-08-04 03:21 | IP: IP Logged
Yes...Great
Thanks
Posted by: AndreasW | Date: 2016-07-22 13:44 | IP: IP Logged
This seems to be still not possible.
I've also tried to manually set 'RightEdge' in PSPad.INI. That worked fine, but only until my source file was externally changed. After I've confirmed that I wanted to reload the file, the vertical line disappeared. So manually editing PSPad.INI is not a solution (at least not until the reload problem is fixed).
Posted by: pspad | Date: 2016-07-22 14:46 | IP: IP Logged
I will check it. You can speed up bug fix if you will provide step by step how to simulate it.
Posted by: AndreasW | Date: 2016-07-22 15:49 | IP: IP Logged
I could not reproduce the problem with reload with a fresh PSPad installation. But here is an even easier method to reproduce it (without any reloading): Please follow these steps:
1. While PSPad is closed, open PSPad.INI and enter the following:
[C/C++]
RightEdge=120
[Config]
RightEdge=0
2. Save PSPad.INI and start PSPad.
3. Open a txt file and a cpp file and verify that the txt file has no vertical line and the cpp file has a vertical line at column 120. So far, so good. That's the desired behavior.
4. Now go to Settings -> Program Settings -> Program (part 1) and make any change.
5. Click the "Apply" button.
As a result, the vertical line in the cpp file will disappear. To make it appear again, you'll need to close and restart PSPad.
Edited 1 time(s). Last edit at 2016-07-22 15:53 by AndreasW.
Posted by: AndreasW | Date: 2016-07-26 13:23 | IP: IP Logged
@pspad: Are you able to reproduce the problem with the instructions I've given in my previous post?
Posted by: pspad | Date: 2016-07-26 15:53 | IP: IP Logged
Hello. I am one week out now. I will look at it as soon as I will return
Posted by: AndreasW | Date: 2016-09-02 09:35 | IP: IP Logged
Have you been able meanwhile to reproduce the problem with the instructions I've given in my above post?
