You are here: PSPad forum > English discussion forum > Re: hex insert
Posted by: bipiw | Date: 2015-07-18 07:27 | IP: IP Logged
Hi.
I needed a hex editor with functionality of inserting new bites(coludnt find in PSPad). Maybe developers should implement such possibilty. I know that i can use some other editor dedicated to hex but PSPad is my favorite. Please consider this topic and let me know what chances are to add function.
Anyway good job will all this editor
Posted by: pspad | Date: 2015-07-18 09:03 | IP: IP Logged
As default you are in overwrite mode. If you want insert new bytes, you need to enter insert mode - press insert key
Posted by: bipiw | Date: 2015-07-18 18:44 | IP: IP Logged
Thanks Right It works. I suspected that it is somewhere. But if i need a thousand of FF at the end of file.. copy paste? function would be usefull in this case.
Edited 1 time(s). Last edit at 2015-07-18 18:49 by bipiw.
Posted by: pspad | Date: 2015-07-18 19:04 | IP: IP Logged
I can add insert sequence function. You will be able define char sequence and count how many you want to insert it.
Posted by: bipiw | Date: 2015-07-18 21:17 | IP: IP Logged
That's great. Is it will be in official version update or as plugin? And how long this can take?
Posted by: pspad | Date: 2015-07-19 06:16 | IP: IP Logged
It will be in official version. And how can it take? I can't tell you now, cause I am hurry in my work and have little time for PSPad.
