You are here: PSPad forum > English discussion forum > Re: How to remove color from tabs?
Posted by: syntech | Date: 2015-07-14 08:31 | IP: IP Logged
I've set tab colors for testing purpose. How can I remove the color from the tabs and make them 'default colored' again?
Thanks and BR
Posted by: pspad | Date: 2015-07-14 09:31 | IP: IP Logged
There are two ways how to set colors:
1. in the highlighter settings you can set color for highlighter - simple remove color in highlighter settings - set it to white
2. you can set color for specific tab - again, set it to white
Posted by: syntech | Date: 2015-07-14 12:08 | IP: IP Logged
I chose setting it to color white, and it works! Thanks a lot!
Before I made the post here I tried to set it to black to 'reset' the color, but that didn't work. Because of that I didn't try it with color white instead...
