You are here: PSPad forum > English discussion forum > Re: Different color for recently modified lines
Posted by: aquabela | Date: 2015-06-07 08:40 | IP: IP Logged
I used to use the multiedit editor for long time writing in C.
Now I moved to the PSPad and like it.
A usefull feature that the Muliedit has is highliting the most recent modified lined with a unique color (configurable). It makes it easy to browse and find those lines.
Is it possible to add this feature.
Thanks
Aqua
Posted by: pspad | Date: 2015-06-07 09:10 | IP: IP Logged
I will take a look if it is possible. It should be possible using undo buffers.
Posted by: bwhawk | Date: 2015-06-08 09:53 | IP: IP Logged
I think this would be a great idea! If it's not too much additional work, would it be possible to have two colors -- one for modified lines before the file is saved and one for modified lines after the file is saved?
Posted by: francheu | Date: 2015-06-08 12:04 | IP: IP Logged
Sounds like a good idea, but I wonder if this is kind of redundant with the diff tool...
François
Edited 1 time(s). Last edit at 2015-06-08 12:04 by francheu.
Posted by: Wirek | Date: 2015-06-27 10:20 | IP: IP Logged
Single colour highlighting (on the margin with line numbers maybe) is a nice feature to have but I'd rather wish to have a keyboard shortcut "Jump to last edited position" (the line and column position or at least the line position).
Posted by: Osca | Date: 2015-08-28 01:03 | IP: IP Logged
Good Ideas! The question is how to acheive that?
Posted by: pspad | Date: 2015-08-28 04:25 | IP: IP Logged
It's planned
