You are here: PSPad forum > English discussion forum > Re: Project Name
Posted by: pythonui | Date: 2015-05-23 09:54 | IP: IP Logged
How can I know the project name in pspad scripting?
Posted by: pythonui | Date: 2015-05-23 10:15 | IP: IP Logged
Got my answer from Help File.
Quote:getVarValue("%ProjectName%")
Edited 1 time(s). Last edit at 2015-05-23 10:15 by pythonui.
Posted by: pspad | Date: 2015-05-23 10:20 | IP: IP Logged
What for is a project name?
You can use script function: projectFileName
If project name is important, I can add script function to get/set project name
Posted by: pythonui | Date: 2015-05-23 10:22 | IP: IP Logged
Thanks for answer!
I am going to write script that will check for "svn st" in project folder!
Is there anything special for this requirement?
Posted by: pythonui | Date: 2015-05-23 10:25 | IP: IP Logged
Second Que: Is there possible to integrate SSH with pspad? (remote connection with ssh)
Posted by: pspad | Date: 2015-05-23 10:28 | IP: IP Logged
I don't know what is "svn st". If it is something with CVS system, you can specify, which files won't be included in the project.
No, there is no integration with SSH.
Posted by: pythonui | Date: 2015-05-23 10:32 | IP: IP Logged
"svn" is subversion.apache.org
"svn st" check for updates in project folder(add,update,delete files)
Posted by: pythonui | Date: 2015-05-23 10:34 | IP: IP Logged
Another way : Is there possible to check which files are modified and which files are not added in project?
Posted by: pspad | Date: 2015-05-23 11:42 | IP: IP Logged
Which files are modified? Do you mean open files in PSPad? Yes, modified() function from scriptiong.
Open files which are not included in project? Yes, you can go through the project files using: projectXXXXX functions in scripting.
Open .\Script\readme.rtf file and read it. It's faster method than ask for individual scripting function. Similar content is in PSPad help
Posted by: pythonui | Date: 2015-05-23 16:43 | IP: IP Logged
Sorry for this thread!
