You are here: PSPad forum > English discussion forum > Re: Request : Code Explorer
Posted by: pythonui | Date: 2015-05-22 10:57 | IP: IP Logged
But in the QBasic we have 'LET' for declaration and assignment both!
You can see in sample code!
Posted by: pspad | Date: 2015-05-22 11:07 | IP: IP Logged
Read the documentation you sent link
Yes, in QBasic (as in each interpreted language) you can use variable without declaration.
See the example:
pastebin.com
What do you want to see in code explorer? List of 'A' variable several times?
Posted by: pythonui | Date: 2015-05-22 11:12 | IP: IP Logged
As in javascript variable name and then list of line numbers(where this variable is used)!
Something like this!
We can use first occurance of variable from top to bottom for list variable name!
Posted by: pspad | Date: 2015-05-22 11:29 | IP: IP Logged
I wrote you, JScript uses VAR as variable definition.
QBasic uses DIM as variable declaration. If you will use DIM, you will see your variables in Code explorer.
Variable occurrences in code explorer was fault and it's for nothing. In my opinion, I would remove it from parsers.
Posted by: pythonui | Date: 2015-05-22 11:32 | IP: IP Logged
Okay! Understand you!
Posted by: pythonui | Date: 2015-05-22 11:48 | IP: IP Logged
Great!
Where can I find code explorer for QBasic?
Posted by: pspad | Date: 2015-05-22 11:52 | IP: IP Logged
Wait for next build in developer forum
Posted by: pythonui | Date: 2015-05-22 11:53 | IP: IP Logged
Ohh! Okay
Waiting!!!!!
Posted by: pythonui | Date: 2015-06-10 09:23 | IP: IP Logged
Hello Jan,
Sorry to disturb again for this!
Quote:Variable occurrences in code explorer was fault and it's for nothing. In my opinion, I would remove it from parsers.
I think this is a nice thing that we can have subroutines occurrences in code explorer with line numbers as we have in javascript(variables count)
Thanks
