You are here: PSPad forum > English discussion forum > New Error!
New Error!
Goto Page: 1 2 3 Next
#1 New Error!
Posted by: pythonui | Date: 2015-05-20 10:02 | IP: IP Logged
Sometime when I try to write "(" then I get following error!!
Exception description:
Exception class:
Exception address:
Stack list, generated 20-May-15 03:31:31 PM
Deleted
Please send such lists to Jan.
Find mail address in Help > About.
Program : C:\Program Files\PSPad editor\PSPad.exe 4.6.0 (2660)
System : Windows 8 Professional x32, Version: 6.2, Build: 23F0,
Processor: Intel, Intel(R) Core(TM)2 CPU 6400 @ 2.13GHz, 2133 MHz MMX
Display : 1280x720 pixels, 32 bpp
Active Controls Hierarchy:
TPSSynEdit ""
TfChildEdit ""
Edited 1 time(s). Last edit at 2015-05-25 18:43 by Stefan.
#2 Re: New Error!
Posted by: pythonui | Date: 2015-05-23 16:51 | IP: IP Logged
Please look into this.Its occur many time when I try to write '('.
If this is some OS related exception then what to do ?
#3 Re: New Error!
Posted by: pspad | Date: 2015-05-23 18:07 | IP: IP Logged
Do you have Windows 8.1?
Did you set any compatibility mode for PSPad? If yes, switch it off.
This error occurred as connection of the 3 things together:
Windows 8.1 + Wordwrap mode + Highlight matching brackets
Switch off WordWrap mode (Ctrl+W)
#4 Re: New Error!
Posted by: pythonui | Date: 2015-05-24 01:37 | IP: IP Logged
I have windows 8.1
I don't set any compatibility mode for pspad.
#5 Re: New Error!
Posted by: pythonui | Date: 2015-05-25 02:46 | IP: IP Logged
Its working !
This is a solution !
#6 Re: New Error!
Posted by: pspad | Date: 2015-05-25 04:09 | IP: IP Logged
The strange thing is for Windows 8.1 it should stop highlight matching brackets if wordwrap is on. Can you confirm it?
If not, it means you run PSPad in any compatibility mode. Please check it.
#7 Re: New Error!
Posted by: pythonui | Date: 2015-05-25 04:18 | IP: IP Logged
My word wrap is off.
I am able to see matching brackets in my python file.
My word wrap is on.
But when I am trying to write '(' then exception occurs.
PS : What is compatibility mode for pspad?(I have not set anything!)
UPDATE : Word wrap is on or off its still highlight the matching brackets! sad smiley
Edited 1 time(s). Last edit at 2015-05-25 04:23 by pythonui.
#8 Re: New Error!
Posted by: pspad | Date: 2015-05-25 04:31 | IP: IP Logged
Do you see matching brackets when WordWrap is on?
Compatibility mode: right mouse on PSPad link or exe / Properties / Copatibility tab
Uncheck compatibility mode if set
#9 Re: New Error!
Posted by: pythonui | Date: 2015-05-25 04:38 | IP: IP Logged
See the image.
I don't set compatibility for pspad.
#10 Re: New Error!
Posted by: pythonui | Date: 2015-05-25 05:19 | IP: IP Logged
What is the problem behind this?
