You are here: PSPad forum > English discussion forum > Re: External Application
#1 External Application
Posted by: pythonui | Date: 2015-05-20 03:17 | IP: IP Logged
I have setup one external application for python(Syntax Checking).
When I called this application with F9 it will open the CMD(Command Prompt). But its close at that moment. I am not able to see content of CMD.
Is there any setting to do?
Edited 1 time(s). Last edit at 2015-05-20 03:17 by pythonui.
#2 Re: External Application
Posted by: pspad | Date: 2015-05-20 03:46 | IP: IP Logged
In your bat redirect output to some file and let the file open as LOG for external application
Another possibility is compiler where you can catch output into log directly
#3 Re: External Application
Posted by: pythonui | Date: 2015-05-20 05:32 | IP: IP Logged
Thanks for answer,
I have ".exe" file for external application.Is that possible to capture external application output to pspad log window or any log file?
#4 Re: External Application
Posted by: pspad | Date: 2015-05-20 05:41 | IP: IP Logged
If you will use Compiler instead of external application, you can simple catch compiler output
If you want to catch output from any exe to file, create BAT, something like:
mybat.bat
myapplication.exe %1 >%2
In the PSPad you will call bat instead of your exe direct call and you will
Call the bat as:
mybat %filename% %Dir%%Name%.log
LOG file: %Dir%%Name%.log
#5 Re: External Application
Posted by: pythonui | Date: 2015-05-20 05:46 | IP: IP Logged
Thanks for your answer,
Its working!!!!
#6 Re: External Application
Posted by: pythonui | Date: 2015-05-20 06:18 | IP: IP Logged
I am not able to edit my previous comment.
UPDATE:
If we dont want to create log file then we can add 'cmd /k' at the end of the bat file to not close the CMD window.!!
