You are here: PSPad forum > English discussion forum > Re: Change the order of the lines
Posted by: Esgrimidor | Date: 2015-05-19 19:59 | IP: IP Logged
Can I change the order of the lines in a txt file in an automatic way. ?
Alleatory.
Best Regards
Nice program indeed
Posted by: pspad | Date: 2015-05-19 20:48 | IP: IP Logged
what does mean change order? sort? use sort function from the edit menu
Posted by: Esgrimidor | Date: 2015-05-20 03:16 | IP: IP Logged
Sorry i am using the term aleatory
Is better express as random
obtain random lines
obtain a scrumble or similar
a sort of jumble of lines
put in random order the lines of text.
Nice program indeed
Posted by: pspad | Date: 2015-05-20 03:43 | IP: IP Logged
You can use Sort function to get some semi-random order.
Select Column, call sort function and let your lines sort using this column.
If it is not enough, you can write script, which will do exactly what you need
Posted by: Esgrimidor | Date: 2015-06-02 23:47 | IP: IP Logged
I don't see the option.
Where is the option ?
Best Regards
Nice program indeed
Posted by: pspad | Date: 2015-06-03 03:19 | IP: IP Logged
Which option?
what is the purpose of your random lines order?
Posted by: Esgrimidor | Date: 2015-06-03 22:47 | IP: IP Logged
The option of using the "Sort Function"
I want the random order to memorize the lines in differents orders.
Best Regards
Nice program indeed
Posted by: pspad | Date: 2015-06-04 05:02 | IP: IP Logged
Open your text
Select Sort function from the menu edit
Check [x]Specify column and fill in begin-end e.g. from 5 to 15
Let PSpad sort your lines
Posted by: Esgrimidor | Date: 2015-06-09 21:01 | IP: IP Logged
Running to try
Best Regards
Nice program indeed
Posted by: Esgrimidor | Date: 2015-06-09 22:17 | IP: IP Logged
works wonderfully !!!!!!!!
Nice program indeed
