You are here: PSPad forum > English discussion forum > Re: Python Syntax Highlight
#1 Python Syntax Highlight
Posted by: pythonui | Date: 2015-05-18 12:27 | IP: IP Logged
I want to change color of function syntax. Is that possible to config?
Like, I have
def functioname():
print "test"
So, I want to change functionname color
Different Que: How to clear Search Results/Log information?
Edited 2 time(s). Last edit at 2015-05-18 12:31 by pythonui.
#2 Re: Python Syntax Highlight
Posted by: pspad | Date: 2015-05-18 12:31 | IP: IP Logged
No, cause "functionname" isn't any "fixed" part of language syntax.
#3 Re: Python Syntax Highlight
Posted by: pythonui | Date: 2015-05-18 12:37 | IP: IP Logged
Thanks for answer.
Just one question:
In the code explorer we can identify classes and functions,So why it's not possible in this case?
#4 Re: Python Syntax Highlight
Posted by: pspad | Date: 2015-05-18 13:00 | IP: IP Logged
It's relative easy to detect function declaration, but much harder is detect function call. And let highlight function name only as declaration and not as function call is "strange".
You may say, that declaration are there, so for highlight function call can be used some list created from declaration. Yes, it can be. But what with system functions, functions imported from external libraries e.t.c.
"Real" IDE has own namespace - it loads all libraries, parse it, e.t.c. But "real" IDE isn't universal, hasn't size of 5MB compiled code...
#5 Re: Python Syntax Highlight
Posted by: pythonui | Date: 2015-05-18 13:06 | IP: IP Logged
Great Answer!
Thanks
