You are here: PSPad forum > English discussion forum > Feature Request: Search in Files without Auto-Close
Posted by: mgutt | Date: 2015-04-22 10:16 | IP: IP Logged
1.) The search in files window closes automatically if it does not find any file. This should not happen.
2.) After the search is finised a popup confirms the search amount. I do not need that. It should close the search in files window and I can look through the search results by myself. The amount is not really important if it is it should be displayed in the search results instead of a separate popup I think. This is more comfortable.
Posted by: pspad | Date: 2015-04-22 10:18 | IP: IP Logged
2. Program settings / Confirmations
uncheck search in files - Sumary
Posted by: mgutt | Date: 2015-04-24 10:00 | IP: IP Logged
This does not avoid closing the search window.
Posted by: pspad | Date: 2015-04-24 11:06 | IP: IP Logged
I know. You wrote 2 questions.
Did you noticed "2." before my answer?
Posted by: pspad | Date: 2015-05-19 11:18 | IP: IP Logged
mgutt:This does not avoid closing the search window.
Will be available in the next build
