You are here: PSPad forum > English discussion forum > Can i use a table with pspad ?
Goto Page: 1 2 Next
#1 Can i use a table with pspad ?
Posted by: Esgrimidor | Date: 2015-04-02 07:57 | IP: IP Logged
Can I simulate a table with pspad in an easy way ?
Best Regards
Nice program indeed
#2 Re: Can i use a table with pspad ?
Posted by: pspad | Date: 2015-04-02 08:03 | IP: IP Logged
What does mean "simulate table"?
#3 Re: Can i use a table with pspad ?
Posted by: toralf | Date: 2015-04-02 09:37 | IP: IP Logged
You could maybe use the script "Align Column".
You use e.g. a pipe as a delimiter between 'cells' and then align by pipe
#4 Re: Can i use a table with pspad ?
Posted by: Esgrimidor | Date: 2015-04-02 15:52 | IP: IP Logged
perhaps i express bad myself.
a Table in pspad
Nice program indeed
#5 Re: Can i use a table with pspad ?
Running to try
Best Regards
Nice program indeed
#6 Re: Can i use a table with pspad ?
Posted by: toralf | Date: 2015-04-02 16:18 | IP: IP Logged
Esgrimidor:
a Table in pspad
PSPad is a plain text editor. It doesn't support 'graphics' in the text. So if you talk about a table of text I assume you mean that text pieces are organized in rows and columns.
If that is the case, then my suggestion above is still valid.
#7 Re: Can i use a table with pspad ?
Posted by: Esgrimidor | Date: 2015-04-02 19:38 | IP: IP Logged
Thanks Toralf.
I was trying to get the extension.
But i don't see !!!
www.pspad.com /de/pspad-extensions.php
Where can i find ?
Best Regards
Nice program indeed
Edited 1 time(s). Last edit at 2015-04-02 19:38 by Esgrimidor.
#8 Re: Can i use a table with pspad ?
Posted by: toralf | Date: 2015-04-02 20:25 | IP: IP Logged
It already is within PSPad. It is a script that comes with it as a standard. It is in the Script Menu. If you do not see this menu you will have to activate internal script support in the program settings
#9 Re: Can i use a table with pspad ?
Posted by: Esgrimidor | Date: 2015-04-02 20:52 | IP: IP Logged
I undertand
I have the spanish interface
Nice program indeed
#10 Re: Can i use a table with pspad ?
Posted by: Esgrimidor | Date: 2015-04-02 20:59 | IP: IP Logged
Done.
I have a new tab now "Guiones"
I see the script that only ask me for the delimiter (.)
But how can i have the table now ?
Best regards
Nice program indeed
Goto Page: 1 2 Next
