You are here: PSPad forum > English discussion forum > (Automatic) hyperlinks to files and folders
Posted by: HeiniK | Date: 2015-03-30 12:14 | IP: IP Logged
Is there an opportunity to automatically create hyperlinks to files and folders? So far, expressions beginning with "http://" are automatically converted to hyperlinks. Can this be extended to expressions beginning with "file:///" ?
Posted by: pspad | Date: 2015-03-30 12:16 | IP: IP Logged
What for is it?
Posted by: HeiniK | Date: 2015-03-30 12:26 | IP: IP Logged
To gather hyperlinks in txt-files. For example if I have a project the locations of literature, coding, papers, graphics should be gathered in a file called Links.txt in the project folder. So far I save the paths in the Links-file and then have to copy and paste them into my file explorer (e.g. Windows Explorer, Total Commaner).
Posted by: pspad | Date: 2015-03-30 12:29 | IP: IP Logged
Select it and use right mouse / open selected file in default application
Posted by: HeiniK | Date: 2015-03-30 12:35 | IP: IP Logged
Thank you very much for the fast reply. This does the trick.
