You are here: PSPad forum > English discussion forum > Re: Feature request: Remove Google from menu, but add to context menu
Posted by: mgutt | Date: 2015-03-25 20:33 | IP: IP Logged
I still do not see the benefit of having a google search box in a menu, but what I really like to see is selecting a text -> right mouse click -> search "function foo(..." in Google. Of course it should be configurable which search engine is used.
Posted by: pspad | Date: 2015-03-25 20:52 | IP: IP Logged
You can configure Help for language (Alt+F1) to use Google search for selected word (Highlighter settings / Specification tab for PHP). And the final you can change shortcut Alt+F1 to another one if it doesn't fit to you.
Posted by: mgutt | Date: 2015-03-26 13:39 | IP: IP Logged
Nice to know, but through the context menu its much more the usual way as it is in the OS where you right click a file to send it by e-mail or selecting a word in the browser to search for it in bing, google or use the dictionary, etc.
Maybe you can think about that.
Posted by: pspad | Date: 2015-03-26 14:32 | IP: IP Logged
Right click / Help for language
Simple fill in google search url into highlighter settings.
Use variable %word% or %seltext% to specify search string
Posted by: mgutt | Date: 2015-03-30 04:08 | IP: IP Logged
"Warning
External hel for PHP isn't assigned.
Go to ..."
In Highlighters Setting -> PHP -> External Application I added:
Name
Chrome
Application:
"C:\Program Files (x86)\Google\Chrome\Application\chrome.exe" "https://www.google.de/search?q=%SelText%"
Any other setting needed?
Posted by: pspad | Date: 2015-03-30 06:42 | IP: IP Logged
In case you use HTML multihighlighter and not PHP highlighter, set it to the base highlighter for multihighlighter.
If you didn't changed it set it to HTML highlighter.
