You are here: PSPad forum > English discussion forum > Pspad homepage, extensions page bug
Posted by: Dan@pspad | Date: 2015-03-15 17:36 | IP: IP Logged
Hello, this is my first post here.
Iv recently installed pspad, few days ago. now i wanted to install some extensions.
But on the extensions :www.pspad.com page only the scripts 1st page is visibile.
either scripts, user convertors nor syntax definition are clicable.
and under :
manage extensions Page: [1], 2, 3, 4
only the page 1 is viewable.
the following links are not accessibile:
www.pspad.com
www.pspad.com
www.pspad.com
they all show up the page number 1.
Greetings. Dan.
Posted by: pspad | Date: 2015-03-15 17:44 | IP: IP Logged
Hello Dan
Thank you for information. I will try to fix it if I will be able. I am not web builder.
Posted by: pspad | Date: 2015-03-15 17:49 | IP: IP Logged
As temporary solution I removed paging, so all extensions are available on first page.
I am working on full fix.
Posted by: Dan@pspad | Date: 2015-03-15 17:55 | IP: IP Logged
Thanks.
Posted by: pspad | Date: 2015-03-15 19:34 | IP: IP Logged
Switching extensions should be ok, extension management still don't work.
There is some problem with .htaccess and $_GET
