You are here: PSPad forum > English discussion forum > Code explorer unsort functions when I save file to ftp
Posted by: Alex | Date: 2015-03-14 07:17 | IP: IP Logged
I edit files with ftp-syncroinisation. I want my functions be sorted in alphabetical order, and there is a button for that like "Sort ascending". But every time I press save - the order is restored.
Posted by: pspad | Date: 2015-03-14 07:25 | IP: IP Logged
Program settings / Tolls
check option [x]Sort Code explorer result alphabetically
Posted by: Alex | Date: 2015-03-15 03:03 | IP: IP Logged
pspad:Program settings / Tolls
The option was checked. So i think that autosort feature is broken.
But Also there was checked option "refresh code explorer content after file save" unchecking it worked for me.
Posted by: pspad | Date: 2015-03-15 08:11 | IP: IP Logged
Can you tell me which highlighter do you use?
Maybe it's question of the one code explorer.
Posted by: Alex | Date: 2015-03-16 23:11 | IP: IP Logged
pspad:Can you tell me which highlighter do you use?
All highlighters. Javascript, PHP, Multihighligher.
Posted by: pspad | Date: 2015-03-17 06:19 | IP: IP Logged
Alex:All highlighters. Javascript, PHP, Multihighligher.
I tested different files and didn't found any what be unsorted In Code explorer.
Can you send me any your file and write me what highlighters is on the statusbar?
Posted by: Alex | Date: 2015-03-19 09:52 | IP: IP Logged
pspad:Alex:All highlighters. Javascript, PHP, Multihighligher.I tested different files and didn't found any what be unsorted In Code explorer.
braveking.ru
In status bar it is "Javascript | DOS | Codepage Ansi (windows)"
Posted by: pspad | Date: 2015-03-19 12:31 | IP: IP Logged
Alex:
OK, you were right. JavaScript, where functions was directly in the root wasn't sorted. Is there any code explorer problem for another language?
Posted by: Alex | Date: 2015-03-20 19:08 | IP: IP Logged
Hmm. It seems to work fine in PHP files.
