You are here: PSPad forum > English discussion forum > Macros loses their shortcut assignments
Posted by: Andreas | Date: 2015-03-09 13:38 | IP: IP Logged
actually on 4.6.0 2653
Hi Jan,
I'm watching this for a long time now also on older versions that the macros unintentionally loses their shortcut assignments (F5, F6 ...). I don't know why and when this happens, eventually after an update, or after doing a setting.
Where is the assignment saved and why does it get lost? Any idea?
Posted by: pspad | Date: 2015-03-09 17:27 | IP: IP Logged
Settings of Macros is in PSPad.INI
Shortcuts are hardly assigned for 4 macros: F5, F6, Alt+F6, Ctrl+Alt+F6
When you assign shortcut to macro, makro is inserted into corresponding position.
E.g. when you assign Alt+F6 to any macro in Macro manager, this macro is inserted into 3rd position.
Any ad-hoc recorder macro is automatically assigned into first position with F5 shortcut.
Posted by: Andreas | Date: 2015-03-10 08:58 | IP: IP Logged
I have recorded 4 macros and assigned the shortcuts to them.
This is in my PSPad.INI
[Macro]
Macro1=Play Macro 1
Macro2=Play Macro 2
Macro3=Play Macro 3
Macro4=Play Macro 4
Next time they lose this assignment I will take a look into PSPad.INI and tell you.
Posted by: pspad | Date: 2015-03-10 09:08 | IP: IP Logged
Try to find some dependencies. Occasional behavior is hard to find
Posted by: Andreas | Date: 2015-03-10 09:36 | IP: IP Logged
Found one dependency. It gets lost when you change the language. Setting in INI is still there. After close and open PSPad macro assignment is back.
