You are here: PSPad forum > English discussion forum > Right click on file tab
Posted by: pythonui | Date: 2015-03-09 08:23 | IP: IP Logged
I have set English lang but dont know why its showing me different lang for one of the option
PSPAD -- latest version -- 4.5.9
Edited 2 time(s). Last edit at 2015-03-09 08:29 by pythonui.
Posted by: pspad | Date: 2015-03-09 08:46 | IP: IP Logged
Thank you for info. There is missing localization string in the file. I will fix it.
Posted by: pspad | Date: 2015-03-09 08:49 | IP: IP Logged
Download the current build from the PSPad developer forum. There is it already fixed.
Simply unpack WITH SUBFOLDERS and replace files or replace .\Lang\English.ini only
Posted by: pythonui | Date: 2015-03-09 09:01 | IP: IP Logged
I have latest build version.
But problem is not fixed. :(
Edited 1 time(s). Last edit at 2015-03-09 09:01 by pythonui.
Posted by: pspad | Date: 2015-03-09 09:40 | IP: IP Logged
Have you updated language files too?
.\Lang\English.ini
Posted by: pspad | Date: 2015-03-09 09:57 | IP: IP Logged
Can you please open this file?
Around line 284 should be:
aTabColor_Caption=File tab color...
If not, it means you didn't update language file from current build or you unpacked whole developer build into one folder.
There is necessary to unpack it with subfolders!!! Don't use stupid integrated ZIP support in Windows.
If you unpack all into one folder, you have mess there.
Open program settings / System integration and switch off explorer integration.
Rename whole folder, e.g. to PSpad editor.bak
Create new PSPad folder
Download the current full portable version and unpack it into your new folder - with SUBFOLDERS! or download current installer and install it.
Look into folder - several files only ins in the PSpad root folder.
Download current build, unpack with subfolders and replace existing files.
Posted by: pspad | Date: 2015-03-09 10:02 | IP: IP Logged
This is content and structure inside PSPad folder:
Posted by: pythonui | Date: 2015-03-09 10:02 | IP: IP Logged
Here you can see that thing is fine.
