You are here: PSPad forum > English discussion forum > Re: V 4.5.9 and DPI
Posted by: jlrjlr | Date: 2015-03-08 18:44 | IP: IP Logged
I have just installed the new version 4.5.9, thanks for keeping improving PsPad
I am very interested by the "better high DPI support" since I am using DPI 150%.
The icone were set automatically to pspad-24.
PsPad look is better, just a small annoyance.
I have 2 lines to tabs the second line is half hidden by the text zone.
Is the some setings I can tweak ?
Thanks for your answer
Posted by: pspad | Date: 2015-03-08 18:54 | IP: IP Logged
Can you send me screenshot please? As I remember, I tested multiline tabs.
It's not easy to keep Windows native application according to all new Windows settings. .NET applications are in better position, but they are not portable.
Posted by: pspad | Date: 2015-03-08 18:57 | IP: IP Logged
OK, it itsn't necessary to send screenshot, I see it on my testing Windows 10. I will try to fix it as soon as possible.
Posted by: pspad | Date: 2015-03-08 19:07 | IP: IP Logged
Test please this build:
Archive contains PSPad.exe only - replace existing one.
This should solve your problem with file tabs.
Posted by: jlrjlr | Date: 2015-03-08 20:52 | IP: IP Logged
I am impressed by the speed of the correction, on a sunday evening !
It works just perfect
Many thanks
Posted by: jlrjlr | Date: 2015-03-13 08:55 | IP: IP Logged
A little glitch on this DPI topic on autocomplete list
In case of ctrl+space : the list is ok but the selected item is a little bit truncated
In case of Ctrl+J : the item of the list item are half overlaping
tested with 150%DPI
This is very minor, I hope it can help having PsPad perfect.
Posted by: pspad | Date: 2015-03-13 08:57 | IP: IP Logged
jlrjlr:A little glitch on this DPI topic on autocomplete list
In case of Ctrl+J : the item of the list item are half overlapingtested with 150%DPI
Thank you for any comment.
