You are here: PSPad forum > English discussion forum > Re: Disable underlining of active tab
Posted by: Andreas | Date: 2015-03-08 17:31 | IP: IP Logged
To me all three states are sufficient. I was wondering why they not should be sufficient.
Edited 1 time(s). Last edit at 2015-03-08 17:31 by Andreas.
Posted by: pspad | Date: 2015-03-08 17:58 | IP: IP Logged
There is a problem if Windows themes are switched off:
Posted by: Andreas | Date: 2015-03-08 18:50 | IP: IP Logged
Yes, but I also did a test with some windows theme options turned off. And it also was ok. Don't know why the active tab is white here.
Edited 1 time(s). Last edit at 2015-03-08 18:51 by Andreas.
Posted by: pspad | Date: 2015-03-08 19:09 | IP: IP Logged
Yes, this is a new option from 4.6.0
Before it looks as my picture. And you are able to disable current tab highlighting by special settings switch.
