You are here: PSPad forum > English discussion forum > How to join lines without adding spaces inbetween?
Posted by: maki | Date: 2015-03-03 12:31 | IP: IP Logged
PSPad when join lines, spaces are added. What should I do when join to any text not add unnecessary spaces?
Edited 2 time(s). Last edit at 2015-04-03 16:21 by Stefan.
Posted by: maki | Date: 2015-03-08 06:14 | IP: IP Logged
Why do not you answer the question?
Posted by: pspad | Date: 2015-03-08 07:30 | IP: IP Logged
Join lines must add some separator. I cant put all text together, its nonsece.
Posted by: maki | Date: 2015-03-08 08:26 | IP: IP Logged
Other editors do not add stupid separators, join each line
Ps. Therefore I think, the PSPad must be destroyed.
Edited 2 time(s). Last edit at 2015-03-08 08:29 by maki.
Posted by: pspad | Date: 2015-03-08 08:37 | IP: IP Logged
ok. I will block you on this forum. I guess it will be better for all. You will use another editor and we will spare time to answer your childish adds.
Posted by: pspad | Date: 2015-03-08 15:48 | IP: IP Logged
maki:Other editors do not add stupid separators, join each line
New build in developer forum has option to join lines without space.
Posted by: Andreas | Date: 2015-03-08 17:03 | IP: IP Logged
@Jan
You don't need to include this option. You simply can replace all line breaks with 'Multiline Search / Replace' to achieve this.
Posted by: pspad | Date: 2015-03-08 17:18 | IP: IP Logged
I know Andreas, but if there is an option Join Lines, it can be customizable (at least a little). In the future, when standard multiline search/replace will be implemented, I can use it for join line or anything else.
Posted by: Andreas | Date: 2015-03-08 17:45 | IP: IP Logged
Ok, just was thinking about keeping the core clean and simple. And I can not imagine a situation when a developer needs an option to join lines with or without spaces. And if he needs it he knows how to do it.
ps I realized that multiline s&r is way more faster than pspad built-in s&r. Even the rollback (undo) is faster.
Posted by: pspad | Date: 2015-03-08 17:59 | IP: IP Logged
I optimized Join line a little, it should be more fast now with new build
