You are here: PSPad forum > English discussion forum > BUG search&replace long line get me error
Posted by: maki | Date: 2015-03-03 00:02 | IP: IP Logged
the text with a large length
I want to replace:
" " (Space)
this
"" (Nothing)
He shows me all the time very stupid!!! bug
I do not use any regular expressions when I remove only spaces !!!!!!!!!!!!!!
Edited 1 time(s). Last edit at 2015-04-03 16:14 by Stefan.
Posted by: pspad | Date: 2015-03-03 06:40 | IP: IP Logged
It shows you exactly what it should.
If you want to remove spaces only, why do you use regular expressions?
If you want to use regular expressions, use \s instead of your " "
Posted by: maki | Date: 2015-03-03 12:26 | IP: IP Logged
Mr. pspsad - Please understand me correctly.
I do not use any regular expressions!
-72614618_355118849. * | -72614618_348306991. *
This is the only text.
I want to remove from the text.
So please do not write to me, that I'm using regular expressions.
Edited 1 time(s). Last edit at 2015-03-03 12:28 by maki.
Posted by: maki | Date: 2015-03-03 12:34 | IP: IP Logged
I want to delete the spaces, which created PSPad, when I wanted to join the lines !!!
Posted by: pspad | Date: 2015-03-03 12:39 | IP: IP Logged
You had checked [x]Regular expressions option in Find/replace dialog.
If you don't want to use regular expressions, uncheck it please.
Posted by: maki | Date: 2015-03-03 15:19 | IP: IP Logged
this is only the text and not the regex.
If you can not understand this mean you're ........
Option[] RegEx. TURN OFF/DISABLE!!!!!!!!!!!!!!!!(prev screenshot)
Use another editor does not show the stupid error "Error in Search ExpresSion"
You are blind and you really see in the picture Turn On (Enabled) regex???
Edited 6 time(s). Last edit at 2015-03-03 15:26 by maki.
Posted by: pspad | Date: 2015-03-03 15:28 | IP: IP Logged
Error in search expression message is displayed only in case Regular expression is checked and search regular expression is wrong - can't be compiled.
I guess when you uncheck it and run Search/replace, you don't see any message about search expression.
Please don't make an idiots from people who are trying to help you.
Posted by: maki | Date: 2015-03-03 15:39 | IP: IP Logged
This is a bug because..
Replace:
SPACE to NOTHING
Short text - there is no error
Long text - error
Edited 1 time(s). Last edit at 2015-03-03 15:39 by maki.
Posted by: maki | Date: 2015-03-03 16:35 | IP: IP Logged
PSPad return an error because not support - very long names
It is not possible to delete all spaces
Deleted only part of the spaces in the text and a stack overflow
Edited 2 time(s). Last edit at 2015-03-03 16:37 by maki.
Posted by: maki | Date: 2015-03-03 16:47 | IP: IP Logged
Bug number 2 :D
PSPad use: 533 MB
Exception class: EOutOfMemory
Exception address:
Stack list, generated 2015-03-03 17:48:53
DELETED
Please do not post such long list to the forum.
Send them to Jan instead (see email address in PSPad > Help > About
Thanks
Active Controls Hierarchy:
TPSSynEdit ""
TfChildEdit "_79"
Edited 5 time(s). Last edit at 2015-04-03 16:07 by Stefan.
