You are here: PSPad forum > English discussion forum > Re: Change Hotkey (for dates)
Posted by: der_stevie | Date: 2015-02-17 13:38 | IP: IP Logged
Hi Folks,
how can I change the Hotkey <br> ctrl+Enter to <br />?
THX
Posted by: pspad | Date: 2015-02-17 13:58 | IP: IP Logged
Go to menu Settings / Edit clip definition file / HTML (or XHTML, depends which one you use)
Search for <br>
Change it to <br />
Posted by: Andreas | Date: 2015-02-17 14:03 | IP: IP Logged
Make sure you're working on an html document not on an xhtml. With html the correct br is <br> with xhtml the correct one is <br />.
The correct versions are already in the DEF files.
You can edit those files be settings-'Edit clip definition file'.
Sorry Jan, didn't read your post.
Edited 1 time(s). Last edit at 2015-02-17 14:05 by Andreas.
Posted by: der_stevie | Date: 2015-02-17 15:00 | IP: IP Logged
Thanks, found the entry, but SaveError
Posted by: pspad | Date: 2015-02-17 18:13 | IP: IP Logged
der_stevie:Thanks, found the entry, but SaveError
If you want to replace files in program files folder, run PSPad with right mpouse as administrator. It will allows you to save code clips file
Posted by: David in Delta | Date: 2015-02-22 23:01 | IP: IP Logged
I give up. I am not a programmer so the technical discussions defeat me. Simply put, my questions is a bit like the beginning of this thread.
In build 4.5.9 (2529) running on Windows 8.1, how do I change the Alt-D function to produce just the date rather than both the date and time? For instance, I want 2015-02-22, instead of 2015-02-22 2:47:09 PM
There doesn't appear to be an HTML.DEF file in the folder I run PSPAD from, although there was a file by that name in the folder I used for version 4.5.7. Alt-D did what I wanted in that version.
When I use the Settings/Edit Cliff Definition File/HTML, I've changed the only thing that resembles a date to %datetime%=@C datetime=,datetime=,,YYYY-MM-DD," but that does nothing, so far as I can tell.
There is nothing in the HTML.DEF that opens with Settings/Edit Cliff Definition File/HTML that seems to resemble @D, although there are lots of @C and @E, etc.
Posted by: pspad | Date: 2015-02-23 06:27 | IP: IP Logged
Open DateTime dialog from the Edit menu and set format for DateTime you need.
In code clips you can use %Date% and %time% variable instead od %datetime%. Format for all variable you can set in menu Settings / Variables
Posted by: David in Delta | Date: 2015-02-23 18:41 | IP: IP Logged
Wonderful! Thank you so much.
