You are here: PSPad forum > English discussion forum > Find duplicated lines in a txt file
Posted by: Esgrimidor | Date: 2015-02-02 20:38 | IP: IP Logged
How can i find or deleted any duplicated lines in a file ?
And lines beginning with 20 equal characters ?
Best Regards
Nice program indeed
Posted by: pspad | Date: 2015-02-03 05:52 | IP: IP Logged
Menu Edit / Line manipulation / Remove duplicate lines
or more sofisticated:
Menu Edit / Sort line with Remove duplicities option
Posted by: Andreas | Date: 2015-02-03 20:58 | IP: IP Logged
You also can try with menu-scripts "Filter lines".
Posted by: Esgrimidor | Date: 2015-02-10 23:32 | IP: IP Logged
pspad:Menu Edit / Line manipulation / Remove duplicate lines
Running to try
Best Regards
Nice program indeed
Posted by: Esgrimidor | Date: 2015-02-11 00:27 | IP: IP Logged
This option is really marvellous
Nice program indeed
Posted by: Esgrimidor | Date: 2015-02-11 00:28 | IP: IP Logged
Andreas:You also can try with menu-scripts "Filter lines".
Owww running to try
Best Regards
Nice program indeed
Posted by: Esgrimidor | Date: 2015-02-11 00:37 | IP: IP Logged
Where is that option.
I have the spanish version .
Are tools - macros ?
a Screenshot may help me ....
Nice program indeed
Posted by: pspad | Date: 2015-02-11 04:42 | IP: IP Logged
Menu scripts
If there is no item scripts, you need to enable it in program settings / System integration - enable scripting support
Posted by: Andreas | Date: 2015-02-11 16:12 | IP: IP Logged
Esgrimidor:Are tools - macros?
No, talkin' about Scripts. Maybe you find it after you did what Jan told you.
Didn't knew about this function "Remove Duplicate Lines" (is it new?). So you don't need filter lines (although it's fun to use )
