You are here: PSPad forum > English discussion forum > Re: Pair tags highlight how?
Goto Page: 1 2 Next
#1 Pair tags highlight how?
Posted by: cornelisdigitaal | Date: 2015-01-17 14:17 | IP: IP Logged
Let me start off by saying that I love PSPad. One of the best inventions since sliced bread!!
I just re-installed PSPad and can't remember what I need to do to have HTML or PHP pair tags highlighted. I remember there used to be a pinkish color emphasizing the end tag of the one I selected.
Any help is appreciated!
Cheers,
Cees
#2 Re: Pair tags highlight how?
Posted by: pspad | Date: 2015-01-17 18:22 | IP: IP Logged
Go to program settings / Editor 1 and check option Highlight pair brackets
#3 Re: Pair tags highlight how?
Posted by: cornelisdigitaal | Date: 2015-01-24 14:47 | IP: IP Logged
Thanks! You are my hero!
#4 Re: Pair tags highlight how?
Posted by: David in Delta | Date: 2015-02-23 19:09 | IP: IP Logged
I have the same problem. Highlight Matching Brackets IS checked, but unlike 4.5.7, the tags don't highlight when I'm in them. The tag pairs that concern me are
<TR></TR>
<td></td>
<p></p>
<UL></UL>
<li></li>
#5 Re: Pair tags highlight how?
Posted by: pspad | Date: 2015-02-23 19:16 | IP: IP Logged
Please check if wordwrap isn't active. Microsoft changed "something" in Windows 8.1 graphic handling what causes exception if wordwrap is active and matching brackets are ON.
#6 Re: Pair tags highlight how?
Posted by: David in Delta | Date: 2015-02-23 19:36 | IP: IP Logged
Yes, that seems to be the problem. Are you working on a solution? I think matching the pairs is extremely useful but only if long lines wrap so both members of the pair can be seen at the same time.
#7 Re: Pair tags highlight how?
Posted by: David in Delta | Date: 2015-08-06 10:11 | IP: IP Logged
I've just installed Windows 10 and I'm pleased to report Highlight Matching Brackets works again (with or without word wrapping).
Edited 2 time(s). Last edit at 2015-08-06 10:13 by David in Delta.
#8 Re: Pair tags highlight how?
Posted by: David in Delta | Date: 2016-01-21 22:24 | IP: IP Logged
David in Delta:
The problem is back in the English version 4.6.0 (2700). I cannot seem to unzip the 4.6.1 (2703) files, so I can't check to see if the propblem is in that version too.
Anyway, the pair tags only work in 4.6.0 (2700) when word-wrap is off.
sad smiley
#9 Re: Pair tags highlight how?
Posted by: okrat | Date: 2016-04-16 06:30 | IP: IP Logged
Při zapnutém zalamování řádků se závorky nezvýrazňují. Můžu pro to něco udělat?
Windows 10
PSPad 4.6.1 (2716)
#10 Re: Pair tags highlight how?
Posted by: Ruben | Date: 2016-09-05 15:29 | IP: IP Logged
Thanks! i use windows 8.1 and it works!
Goto Page: 1 2 Next
