You are here: PSPad forum > English discussion forum > Re: Multi column edit
Posted by: target232 | Date: 2015-01-13 09:20 | IP: IP Logged
Hi
First PSPad is a great tool and keep the good work!
Can PSPad do multi column edit like notepad++ ?
notepad-plus-plus.org
is there addon for that?
thank you
Posted by: vserghi | Date: 2015-01-20 09:20 | IP: IP Logged
Either press Alt and move mouse, or you can go to Edit > Selection Type > Column Selection, or double click the icon on the botton status bar to cycle through the three options
Vas
Posted by: Neil | Date: 2015-01-20 20:52 | IP: IP Logged
vserghi:double click the icon on the bottom status bar to cycle through the three options
Hi Vas,
I've been using PSPad for about 6 years and I didn't even know about the status bar option !! (yes - I know I should read the help file).
I knew about column mode, but not about the 3rd option - line mode (very handy).
Also, after finally reading the help file I've discovered "Block Mode". Wish I had of known about this before !!!
Just to clarify your post - I think you you only have to single click the icon.
Thanks,
Neil
Posted by: vserghi | Date: 2015-01-21 11:44 | IP: IP Logged
The single/double click on the status bar is dependant on your settings (Program (Part 2)).
Vas
