You are here: PSPad forum > English discussion forum > Re: Small (KiXtart?) highlighting problem
Posted by: @msterdam | Date: 2015-01-12 11:06 | IP: IP Logged
Since the last couple of PsPad beta versions (up to version 2525) there is a small problem with syntax highlighting for KiXtart scripts.
There sometimes appears a kind of cursor symbol at the end of a comment line.
It is a kind of vertical line symbol.
See this example:
postimg.org
It is like being part of the last character, and sometimes looks like being "bold".
At least the characters rCEFGNPTUV are sensitive to it.
It does not happen always, and appears to depend on the length of the script.
It sometimes even depends on the scroll location in the window.
It looks like it also depends on the used font. I am using Courier New (the default?).
It happens on several PCs with different Windows versions and hardware, so it probably is not driver related?
It is not a big problem, but I am curious to know what is causing this.
Posted by: pspad | Date: 2015-01-12 11:17 | IP: IP Logged
Hello.
Go to menu format/font and change font to Consolas - it's better. I have to check whats wrong with Courier New.
Posted by: @msterdam | Date: 2015-01-12 12:30 | IP: IP Logged
Thanks for your quick reply!
Yes, with Consolas it works better, but it still isn't gone completely.
See:
postimg.org
Regards,
Posted by: pspad | Date: 2015-01-12 12:42 | IP: IP Logged
I will take a look of it. If I will fix Courier New, it will automatically fix others too.
Posted by: @msterdam | Date: 2015-01-12 13:02 | IP: IP Logged
OK, thanks.
I did check all font types now, and it looks like that with Monospac821 BT it does not appear at all.
Posted by: pspad | Date: 2015-02-10 13:11 | IP: IP Logged
I hope I found a problem. It should be fixed in next build
