You are here: PSPad forum > English discussion forum > Problem with file name in the ftp tab
Posted by: adam | Date: 2015-01-02 16:23 | IP: IP Logged
I use PsPad from many years ... and it is very nice software.
Now i have a problem.
I use PsPad to connet (via FTP) to a workspace.
Then i use the FTP browser (i dont know the exact name, the tab on the left side of PsPad) to open/modify my files.
I save my files in the format: [10 numbers].txt .
The [10 numbers] are the return of the PHP function time().
Till 19/12/2014 PsPad shows correctly all the files, after that day it shows [only last 4 numbers].txt .
And it cannot open/modify (also rename) those files.
I tried to connect with the browser (FF) to my workspace, and the files are stored correctly.
Here there is an image of the FTP tab
www.dropbox.com
How can i solve this problem ?
Thanks very much.
Posted by: pspad | Date: 2015-01-02 17:47 | IP: IP Logged
It looks like your FTP server doesn't return correct file list in MLSD format.
Go to your FTP connection settings and check Use old file list option
Before you will do it, open FTP LOG window (Ctrl+L) and press LIST button (the first one) on the left side of LOG window. Send me please the log result, enough is file list. I will check if there isn't problem on PSPad side.
Posted by: adam | Date: 2015-01-02 19:30 | IP: IP Logged
Also PsPad v 4.57 didn't show correctly those files (i updated PsPad today to try to solve the problem).
In the option i've already flagged "Old file listing (LIST instead of MLSD)" but it didn't solve the problem.
I did what you asked, but i cannot copy the FTP Log, so i did a screenshot where you can see:
- in the first 2 lines, two file that PsPad shows [10 numbers].txt
- other lines, files that PsPad shows [4 numbers].txt
Edited 1 time(s). Last edit at 2015-01-02 19:31 by adam.
Posted by: pspad | Date: 2015-01-02 19:56 | IP: IP Logged
I don't need screenshot, I need RAW output of the LIST command to test FTP list parser in PSPad.
There is one big problem with FTP servers. Each server has own LIUST output, cause there is no standard. Some standard comes last years with MLSD command, but how it looks like, your FTP server doesn't support it.
If you will send me LOG with LIST output as attachment into support mail, I can test and fix parser. It's important to send it as attachment and not mail body, cause each space is important!
Posted by: adam | Date: 2015-01-02 23:13 | IP: IP Logged
i don't how to send you the LOG.
i press LIST button (top button on the left side as you wrote), then how can i send all the log to you ?
I tried to copy and paste to a *.txt file, but it didn't work.
Posted by: pspad | Date: 2015-01-03 07:36 | IP: IP Logged
Use right mouse button in the LOG window
Posted by: adam | Date: 2015-01-03 22:37 | IP: IP Logged
when i use ight mouse i can choose:
- copy
- copy all
I tried both but nothing. When i open a *.txt and use right mose -> paste, nothing happen. I tried also selecting a part of the log or all the log. It doesn't copy anything.
If you have any idea i can try.
Posted by: pspad | Date: 2015-01-04 10:20 | IP: IP Logged
Hello, you are right, the copy must be fixed.
The second button on the left side of log window allows you to send FTP log via e-mail. Use it please.
Posted by: adam | Date: 2015-01-04 14:28 | IP: IP Logged
i want to cry ...
if i push on the second button as you wrote, it became this new window (see the image)
what i must do ?
Posted by: pspad | Date: 2015-01-04 14:38 | IP: IP Logged
Do you use any Mail client? Go to program settings / Internet and choose the one you use on the bottom of dialog. It usually works for the default mail client without necessary set it.
If it doesn't help you, wait a while, I will fix copy FTP log content into clipboard.
