You are here: PSPad forum > English discussion forum > Matching parentheses are not highlighted and the cursor disappears
Posted by: pspad | Date: 2014-12-08 20:09 | IP: IP Logged
Missing cursor bug found and fixed (I hope)
Posted by: AskMe | Date: 2014-12-09 10:12 | IP: IP Logged
We wait for the next beta build
Posted by: carbonize | Date: 2014-12-09 22:27 | IP: IP Logged
pspad:AskMe:It does not contain something like Google Adsense.
Here elementary html<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
</head>
<body>
<script>
alert(1);
</script>
aaaaaaaa
bbbbbbb
</body>
</html>If you click in the editor view, there are two options:
- A page appears alert, press enter immediately close the window and return to the editor. The cursor is visible, and it is there where it was abandoned.
- A page appears alert, press enter, you can click on that page on the body, and then close the window and return to the editor. The cursor is not visible, but where it was left visible yellow strip line on which the cursor should be.I found way how to simulate it.
If you display WWW preview, close alert box, click into preview window (into browser place) and close the preview window, cursor disappear. You have to swith to another application and back to make it visible.
@Askme so you did exactly what I described and what Jan has also done. Create HTML, preview internally, click preview winodw, close preview window, cursor gone. Glad you have found th eproblem. This has been annoying me for over a year.
Carbonize
Posted by: AskMe | Date: 2014-12-10 11:14 | IP: IP Logged
So I like it when the desired button (1 piece) stands out from the rest:
img2.tempfile.ru
Posted by: pspad | Date: 2014-12-10 11:28 | IP: IP Logged
AskMe:So I like it when the desired button (1 piece) stands out from the rest:
What do you mean?
Posted by: AskMe | Date: 2014-12-13 08:48 | IP: IP Logged
Show page internal browser.
I simply made brighter compared with the other buttons, will find its way to the menu bar at the top.
This fact does not affect the operation of the program, and concerns only the visual perception and ergonomics (concentration or dispersion of attention).
When during the day every ten seconds to switch modes reviewed / edit it plays a role.
Posted by: pspad | Date: 2014-12-13 09:26 | IP: IP Logged
Show page in internal browser - if you use this function more often, use F10. It's faster than press any button with mouse.
Posted by: pspad | Date: 2014-12-13 09:27 | IP: IP Logged
Or if you want to have your own iconset, modify existing one, save it with different name into Skin folder and select in program settings / Program 1
Posted by: AskMe | Date: 2014-12-15 20:08 | IP: IP Logged
Yes, I did.
Posted by: AskMe | Date: 2014-12-22 14:19 | IP: IP Logged
Quote:Missing cursor bug found and fixed (I hope)
Where can I download the fix?
(on the cursor, propane)
