You are here: PSPad forum > English discussion forum > Request: support for wildcards on command line
Posted by: Gorlash | Date: 2014-11-27 15:28 | IP: IP Logged
Okay, I really hope I'm not sounding ungrateful now; I'm TRULY grateful for all the command-line support that you've recently added for me!!
Is it possible to get added support for wildcards on the command line??
for example, "pspad *.iss" ... (I use this particular command every time I need to release a new version of my software package here)
Right now, to add a group of files to the editor, I either need to load them one at a time, or open explorer then select and drag-n-drop to the editor. The above option would be useful to me.
Happy holidays...
Posted by: pspad | Date: 2014-11-27 15:31 | IP: IP Logged
The support for wildcards already exists. But it's limited for wildcards in filename, not in the path
Posted by: Gorlash | Date: 2014-11-28 02:37 | IP: IP Logged
hmmm... unfortunately, that's another one that only works if pspad is *not* already open!!
I'm in a directory containing the following files:
elcal.iss
inno.chinese.iss
inno.iss
If pspad is *not* open, "pspad *.iss" works as expected. However, if it is already open, only the first file (inno.iss) is loaded...
Edited 1 time(s). Last edit at 2014-11-28 02:37 by Gorlash.
Posted by: pspad | Date: 2014-11-28 08:49 | IP: IP Logged
OK, fixed. Wait for the next build.
Posted by: Gorlash | Date: 2014-12-01 02:27 | IP: IP Logged
Yes!! build 2521 appears to work with all current and previous issues, as far as I can recall all the different forms to test.
Thank you again for all of your assistance.
Gorlash
