You are here: PSPad forum > English discussion forum > Bracket autocompletion very slow in win8
Posted by: father_gorry | Date: 2014-11-26 17:14 | IP: IP Logged
Hi.
I've just switched from XP to Win8.1 Installed new PSPad. Checked "complete chars [({" (not the "smart completion").
And it started to do it very. VERY slow. It takes about 2-5 seconds to complete a single bracket.
The bigger the file, the slower is autocompletion. I've got worst results on 20kb file with program code.
The slowness is not persistent: first time it happens, then next char of the same type (eg [3s][0s]) is completed simultaneously. But after some time it becomes slow again.
Under winXP there's no such error.
Edited 1 time(s). Last edit at 2014-11-26 17:14 by father_gorry.
Posted by: pspad | Date: 2014-11-26 19:16 | IP: IP Logged
Do you use the current PSpad version? At least 4.5.8, but I suggest you to update to current developer build 4.5.9
Posted by: father_gorry | Date: 2014-11-26 19:22 | IP: IP Logged
I'm using 4.5.8 (2500)
