You are here: PSPad forum > English discussion forum > Re: How to create a custom macro to replace html entities
Posted by: STing | Date: 2014-11-25 10:56 | IP: IP Logged
Folks,
Is it possible to create macro to replace common HTML entities when editing XML files?
(http://en.wikipedia.org/wiki/List_of_XML_and_HTML_character_entity_references)
Example of source text:
the <b>top 5 most critical business priorities</b> that you will personally be involved <br>in over the next 12 to 24 months. <p><i>These may or may not include those that you supplied.</i> ^f("hInstructions")[65].label()^ <br><br> <span class="instruction"...
Expected transformation after running the macro:
the <b>top 5 most critical business priorities</b> that you will personally be involved <b>in over the next 12 to 24 months. <p><i>These may or may not include those that you supplied.</i> ^f("hInstructions")[65].label()^ <br><br> <span class="instruction"...
Thanks.
Posted by: pspad | Date: 2014-11-25 11:26 | IP: IP Logged
Use user convertors from the tool menu. There are ready use convertors what did thing you need.
You can simple create new one or modify existing.
Posted by: STing | Date: 2014-11-25 12:24 | IP: IP Logged
Thank you - that works well
