You are here: PSPad forum > English discussion forum > How to remove that 'time tags' from file?
#1 How to remove that 'time tags' from file?
Posted by: patrickh111 | Date: 2014-11-17 19:15 | IP: IP Logged
Hi, i working new for several years with PSPad and never have a problem until now...
i have files were i have to delete some text, i give at once the problem here:
i´ts about a GPX file where i have to delete all the time tags
<trkpt lat="47.410760000" lon="12.714200000">
<ele>1750.000000</ele>
<time>2012-05-01T08:00:00Z</time>
</trkpt>
<trkpt lat="47.410490000" lon="12.714190000">
<ele>1752.000000</ele>
<time>2012-05-01T08:00:33Z</time>
</trkpt>
<trkpt lat="47.410330000" lon="12.714160000">
<ele>1753.000000</ele>
<time>2012-05-01T08:01:06Z</time>
</trkpt>
As you can see every tag <time>2012-05-01T08:00:00Z</time> has another code, the whole tag with the time has to be deleted.
I did try with search and replace but did not find out how to do that sad smiley
please help
edit from "help needed" to "How to remove that text from file?"
Edited 2 time(s). Last edit at 2014-11-18 06:37 by Stefan.
#2 Re: help needed
Posted by: pspad | Date: 2014-11-17 19:34 | IP: IP Logged
1. Search / Replace dialog with regular expressions
Search: <time>.*</time>
Replace:
[x]Regular expression
After it use menu Edit / Lines manipulation / Remove blank lines
2. Find + Copy nonmatching
Replace:
[x]Copy nonmatching
press copy button and you will get your content in new editor window
#3 Re: help needed
Posted by: patrickh111 | Date: 2014-11-17 20:06 | IP: IP Logged
Thanks, it works, i did try <time>*</time> just a point away smiling smileysmiling smileysmiling smiley
