You are here: PSPad forum > English discussion forum > Line numbers do not match with line-height
Posted by: whacker | Date: 2014-11-16 13:55 | IP: IP Logged
Been working with pspad and php for years now.
Then I got to thinking to increasing the line-height so that I can see the lines of text
better.
The line-height did work. But the line numbers do not sync with the new line-height. There
are times a line of text is between 2 line numbers and this causes confusion when you are
collaborating with fellow programmers even if they are using pspad on the other end.
Kindly have this fixed.
Would love to see pspad have code-folding. Everything else is perfect.
Edited 1 time(s). Last edit at 2014-11-16 13:55 by whacker.
Posted by: pspad | Date: 2014-11-16 16:46 | IP: IP Logged
How did you increase line height?
Can you write what did you do and send me screenshot? I tested both way I know - Ctrl+mouse wheel and Extra line spacing in program settings / Direct edit. Both way have line numbers synchronized with lines.
Posted by: panos | Date: 2016-12-03 10:52 | IP: IP Logged
Posted by: pspad | Date: 2017-01-14 13:52 | IP: IP Logged
I found a reason. This situation accurs if ExtraLineSpacing special option isn't set to 1. I must look in editor component code and find how to fix it.
Posted by: pspad | Date: 2017-01-14 14:05 | IP: IP Logged
Problem found and fixed. Available in the next build
