You are here: PSPad forum > English discussion forum > How to run command when the path has ampersand?
Posted by: Get Free | Date: 2014-11-14 19:39 | IP: IP Logged
In the dialog "Tools > Command Line", if the command path has an ampersand, it does not work if you choose "Run under MS-DOS command interpreter".
It doesn't help either if you enclose the path in quotes.
However, if I open a MS-DOS window and type the command path (enclosed in quotes) it works fine.
Is there a solution for this?
