You are here: PSPad forum > English discussion forum > synedit (again) for code folding
#1 synedit (again) for code folding
Posted by: gwinkless | Date: 10/30/2014 12:39 | IP: IP Logged
I'm aware code folding pops up as a request every so often, but I couldn't find any mention of this version of synedit (only of the 1.0.3 version that seemed to have stalled).
Would it be possible to use the forked version of synedit from the freepascal guys?
wiki.freepascal.org
It appears to be actively maintained and (from downloading their IDE and playing for a bit) the modifications appear to work well.
I'm not a delphi programmer though, so I've no idea whether the changes they've made to make it integrate with their IDE will have broken it for use elsewhere, or indeed if it would only run under freepascal.
#2 Re: synedit (again) for code folding
Posted by: pspad | Date: 10/30/2014 14:26 | IP: IP Logged
I will look at it.
Synedit used in PSpad is little modified. I need test their Synedit and apply my changes to it.
#3 Re: synedit (again) for code folding
Posted by: gwinkless | Date: 11/04/2014 09:28 | IP: IP Logged
I will look at it.
Can't ask any more than that, thanks!
They have multiline regexp in their search/replace, too (and in their in-file search) although whether that's a synedit modification or something they've written externally I don't know.
#4 Re: synedit (again) for code folding
Posted by: pspad | Date: 11/04/2014 11:02 | IP: IP Logged
I looked at it (shot time only), but they have own modified version for FreePascal only. It isn't usable for Delphi.
But I can look at specific parts as search e.t.c.
#5 Re: synedit (again) for code folding
Posted by: gwinkless | Date: 11/24/2014 13:15 | IP: IP Logged
OK, thanks for taking the time. I've no idea about freepascal vs delphi, I'd read that one of their goals was compatibility so I had hoped that it would be useful for PSPad.
I never use code folding so it doesn't bother me anyway smiling smiley
Edited 1 time(s). Last edit at 11/24/2014 13:15 by gwinkless.
#6 Re: synedit (again) for code folding
Posted by: pill | Date: 07/04/2018 06:55 | IP: IP Logged
gwinkless:
But the rest often use! This is a very necessary addition.
