You are here: PSPad forum > English discussion forum > Filtering of file names in the ftp panel
Posted by: still | Date: 2014-10-13 14:59 | IP: IP Logged
Is there or will be in the future the ability to filter file names in the ftp panel.
Now, if there are many files in a directory
to find a particular file is a big problem.
And of course I do not mean to search files on the server
but search (filtering) list already received from the server
like Quicksearch filter in TC
vide link www.ghisler.com
Posted by: Andreas | Date: 2014-10-14 11:37 | IP: IP Logged
+1
Posted by: pspad | Date: 2014-10-14 11:47 | IP: IP Logged
search on the server side isnt possible, cause ftp doesnt support it. Quick search in listed results isnt so complicated to do.
Posted by: still | Date: 2014-10-22 10:59 | IP: IP Logged
pspad:Quick search in listed results isnt so complicated to do.
search on the server side is not needed.
but filtering already downloaded file list would be very very helpful
Please remember about Qsearch in ftp list in future versions
Edited 1 time(s). Last edit at 2014-10-22 11:00 by still.
Posted by: pspad | Date: 2014-10-22 11:12 | IP: IP Logged
Should it apply for files only or for folders too?
I think to make quicksearch as filter. You fill in into edit control any string and PSPad will show you files containing this string
Posted by: Andreas | Date: 2014-10-22 11:35 | IP: IP Logged
I think it should be for files only. If I i.e. type in "*.php" I still like to be able to switch folders else I first have to deactivate the filter before switching to another folder.
Posted by: pspad | Date: 2014-10-22 14:52 | IP: IP Logged
OK, quick filtr is ready.
It will be applied to files only.
It will filtr list to filenames containing filled in string. E.g. .php will filtr out PHP.
there is no necessary to enter wildcards
