You are here: PSPad forum > English discussion forum > question about installers and configuration
Posted by: Gorlash | Date: 2014-10-07 21:45 | IP: IP Logged
I installed the "portable" version of pspad (i.e., from the zip file). In this situation, all the configuration and customization files are stored in the pspad directory.
I was wondering, if one installs from the executable installer, are the configuration files still in the pspad directory, or do they end up somewhere under the User\username directory ??
Posted by: pspad | Date: 2014-10-08 04:21 | IP: IP Logged
The configuration file placement depends of parameter Multiuser environment in Program file / System. If you will activate it, PSPad will copy config files into user profile folder.
Current placement you see in Program settings / Backup. You can create backup of your config files and restore them too if you don't like to do it manually.
