You are here: PSPad forum > English discussion forum > Re: Cannot write Polish 'ł', 'Ł', 'ś' or 'Ś'
Posted by: Ruud | Date: 2014-10-03 16:07 | IP: IP Logged
I'm Dutch and have a Polish wife. I have an US international keyboard but I set to Polish programmer. That works fine in various programs except PSPad. When I wanted to write the Polish ł by pressing 'Alt gr' (the Alt button at the right site of the space bar), I got this question if I wanted to turn everything in lower case. The settings say that that should happen with 'Ctrl+ALt+L' which indeed does the same. I solved the problem for the moment by using 'Ctrl+ALt+;'.
I have the same problem with 'ś' or 'Ś', solved by using 'Ctrl+ALt+T'.
Is there a solution so I can use the origial settings again?
Thank you very much in advance!
Kind regards, Ruud Baltissen
www.Baltissen.org
Posted by: pspad | Date: 2014-10-03 16:13 | IP: IP Logged
Go to program settings / KeyMap
Remove shortcuts what are using in PSPad and you use it to write your letter. Ctrl+Alt = AltGr (right alt)
Posted by: Ruud | Date: 2014-11-05 07:25 | IP: IP Logged
Thank you very much!
Edited 1 time(s). Last edit at 2014-11-05 07:26 by Ruud.
This Thread has been closed
