You are here: PSPad forum > English discussion forum > Multi-Search
Posted by: pspad | Date: 2014-10-05 10:58 | IP: IP Logged
OK. Several useful suggestions for you:
- If you are not able to write longer sentences, write more short ones. If you write 2 short sentences only, nobody will understand you.
- Use examples - original lines and result what you want to get. Example will tell more than long description.
Write example as text, not as pictures. Picture is good to show something (good for your request what you want to extend). But picture is unusable for text processing. Nobody has enough time to rewrite text from your pictures e.g. to test regular expressions.
- Before you will send request, try to think if people will be able to understand you. Read it twice or more times before sending.
- Try to be polite, don't use rude words. Why should people waste their free time with you, if you don't react on their questions, when you answer nonsenses. You are the one who is asking for help. People here are not paid to answer you. It's their own will and decision if they will spend their own free time with you or they won't.
Posted by: maki | Date: 2014-10-05 11:15 | IP: IP Logged
PSPad 4.9.0
I'll try to explain with an example.
1.Open text file
2.Find all the names in the lines?
3.Copy all the lines.
example: Y:\FolderName\Sub-FolderName\b_6c663ccc.jpg
Find
Posted by: maki | Date: 2014-10-05 11:22 | IP: IP Logged
Possible add all name ?
Posted by: pspad | Date: 2014-10-05 11:37 | IP: IP Logged
Small recapitulation:
original lines:
search for:
you want whole file names include path in result. Using regular expressions you have to search for:
or use simple search without regular expressions for t_db1234568786e.jpg and PSpad will copy into new file whole lines containing text you search for.
If you want to use regular expressions to search for more results, search for:
^.*\\t_db1234568786e\.jpg|^.*\\b_6c663ccc\.jpg|.....
But you are limited to 2048 chars
PSPad doesn't allows you to insert more lines into search field.
Posted by: maki | Date: 2014-10-05 11:59 | IP: IP Logged
Quote:PSPad doesn't allows you to insert more lines into search field.
What Professional tool allows you to insert more?
I want to find 5000 names.
Edited 3 time(s). Last edit at 2014-10-05 12:01 by maki.
Posted by: pspad | Date: 2014-10-05 12:40 | IP: IP Logged
I am sorry maki, I don't know such tool. Your request is too specialized.
If more PSPad users will like this functionality, I will add it.
I suggest you to write it as new topic. You have already good description and examples to do it.
Posted by: maki | Date: 2014-10-05 13:23 | IP: IP Logged
Every time when I want to,
a)find,
b)edit,
c)open,
etc.
always limits:
1. Limit Chars
2. Limit 2 GB (32-bit)
3. Limit Lines
4. Other limit
Google:
"how to without limited to 2048 chars"
- no solution
Edited 1 time(s). Last edit at 2014-10-05 13:26 by maki.
Posted by: pspad | Date: 2014-10-05 13:40 | IP: IP Logged
You are using wrong way to process your data. You should use database. It will allows you to work without limits.
Example for simple database with 2 tables
Table1 with structure FileName varchar(255)
Table2 with structure ListItem varchar(255)
import file with your filenames into Table1 and list of strings you want to search for into Table2
in both tables you can have (from your point of view) unlimited number of rows
To get result for rows from Table1 containing strings from Table2 use query:
Quote:select Table1.*
from Table1, Table2
where Table1.FileName like '%' + Table2.ListItem + '%'
Posted by: pspad | Date: 2014-10-05 13:47 | IP: IP Logged
Of course it is possible with "editor" like tool. Imagine you have 400 000 file names and 5 000 strings you want to look for. Editor needs to make 400 000 x 5 000 string compares to show you result = 2 000 000 000 text compares! It isn't possible be done in one or two seconds.
Posted by: maki | Date: 2014-10-05 13:56 | IP: IP Logged
pspad:It isn't possible be done in one or two seconds.
Ok, understand, but This may be done in 24 hours (one day progress)?
For me, there really is no matter how many time.
For me the most important thing is to make it work.
Edited 1 time(s). Last edit at 2014-10-05 13:57 by maki.
