You are here: PSPad forum > English discussion forum > Re: All the time occurring write error
Posted by: maki | Date: 2014-09-30 17:09 | IP: IP Logged
All the time occurring write error.
I click OK, and again and again and again - locks the program (the active window ERROR)
Conflict with OpenOffice Calc
Edited 1 time(s). Last edit at 2014-09-30 17:11 by maki.
Posted by: pspad | Date: 2014-09-30 17:21 | IP: IP Logged
Calc locks the file for itself only. It's same with MS Office.
PSPad can't write into file locked by Calc. It's Windows or Calc message, not PSPad message.
Why is your problem here and not in the Calc forum?
Posted by: maki | Date: 2014-09-30 17:49 | IP: IP Logged
Because I do not want to register on the forum Office.
Posted by: pspad | Date: 2014-09-30 18:21 | IP: IP Logged
In this case I have only advice for you: close file in Calc, then you will be able to save it in PSpad.
If you want Calc stop blocking other programs, ask Calc developer to change Calc behavior.
Posted by: maki | Date: 2014-10-01 17:52 | IP: IP Logged
pspad:then you will be able to save it in PSpad.
I generally do not even save a file !!, the file is only opened in the editor...
Issue: Automatic Save (backup) [...:... min] "~"
OpenOffice developer said that the problem is PSPad, not OpenOffice.
Test Other Editor:
OpenOffice Calc open file + AkelPad open file... Work (not write error)
Edited 4 time(s). Last edit at 2014-10-01 18:01 by maki.
Posted by: pspad | Date: 2014-10-01 18:26 | IP: IP Logged
OK. Now you say the important information what was missed again as usually - you set autosave interval.
It means PSpad saves your file automatically each time acording to interval.
PSPad can't write into file if this file is open in CALC. CALC locks this file for itself and prevent other program to write into file. Do you understand it?
Your other editor has no autosave possibility or you don't activate it. If you will switch autosave off in PSPad, you wont see any warning messages too.
In case PSPad won't show you information that file wasn't saved (even you set autosave interval) it would be worse. User will think the file was saved, but it wasn't cause other program (CALC) block access to this file.
So what do you offer? What is your advice?
P.S. I forgot. PSpad trying save file in case file is modified only. It means if you open same file sa CALC and you wont make any changes in file, you won't see any message.
It means you didn't write truth you only open the file
Edited 1 time(s). Last edit at 2014-10-01 18:36 by pspad.
