You are here: PSPad forum > English discussion forum > Re: feature request: single-key line delete
Posted by: Gorlash | Date: 2014-09-29 20:44 | IP: IP Logged
This is a function that I've had in my past editor (MultiEdit), and tend to use alot.
I was thinking that it would be easy to implement with Control-X; if user hits control-X, but no text is highlighted, then just delete the entire line including newline. The current cursor position should be ignored.
Please consider this, if you have time to look into it.
Edited 1 time(s). Last edit at 2014-09-29 20:44 by Gorlash.
Posted by: pspad | Date: 2014-09-30 03:33 | IP: IP Logged
Standard in editor world for line delete is Ctrl+Y
If you want to have it as Ctrl+X, you can redefine it in Program settings / Key Map in editor commands section. Look for LineDelete
Posted by: Gorlash | Date: 2014-09-30 14:29 | IP: IP Logged
Oh My !!! Control-Y is perfect!! I just didn't know about it; it's not included in your "Keyboard shortcuts" page, or else I'm just blind...
That's fine, thank you very much!
Later note:
1. I don't actually *see* "LineDelete" in Program Settings: KeyMap: Edit section; do I need to add that somehow??
2. Also, a line that I delete using Control-Y is not in the clipboard buffer, so I cannot insert it elsewhere using Ctrl-V ; is there a LineInsert function or some such?
Edited 1 time(s). Last edit at 2014-09-30 14:37 by Gorlash.
Posted by: Gorlash | Date: 2014-09-30 19:38 | IP: IP Logged
Oops, nevermind... I was looking at the "Edit" group, not the "Editor" group... now I see everything!!
Unfortunately, InsertLine does not actually insert what I previously LineDeleted...
I tried assigning it to a different key (Ctrl-I), but that made no difference;
InsertLine appears to just insert a blank line; I need to be able to insert what I previously DeleteLined... can I do this??
Edited 1 time(s). Last edit at 2014-09-30 19:44 by Gorlash.
