You are here: PSPad forum > English discussion forum > PSPad - application is unstable
Posted by: maki | Date: 2014-09-27 21:43 | IP: IP Logged
PSPad -
NON-STOP (!!!!) 25% CPU (HANG) Unstable !!!!!
ram - Only 66 MB
Edited 1 time(s). Last edit at 2014-09-27 21:43 by maki.
Posted by: pspad | Date: 2014-09-27 21:43 | IP: IP Logged
Pspad main purpose is code editor - edit source code. If you want to work with huge files, find yourself another tools. PSPad isnt suitable to it.
Posted by: maki | Date: 2014-09-27 21:47 | IP: IP Logged
You do not understand me.
PSPad - has options that do not have a different editor, although such. EmEditor opens huge files.
How multi-option few editors. Why edit and search for names in the text is such a difficult and complicated.
For many weeks I can not solve this problem. I've lost a lot of time f*ck !
Posted by: maki | Date: 2014-09-27 21:55 | IP: IP Logged
Best idea...Need regex:
Find ALL
PATH
Y:\NEW 2\.............................
Posted by: pspad | Date: 2014-09-27 21:59 | IP: IP Logged
If you want to search in huge files and copy results into new file, why you don't use some command line tool like Windows PowerShell? It's easy to use:
Select-String c:\Temp\0008.txt -pattern "ODB_0DJ0GBH0C" >result.txt
You can use it for any TXT file in folder e.t.c.
More details here:
technet.microsoft.com
Posted by: maki | Date: 2014-09-27 22:03 | IP: IP Logged
Select-String : A positional parameter cannot be found that accepts argument 'folder\0'.
At line:1 char:1
+ Select-String K:\tempz\Nowy folder\0 utf-8.txt -pattern "NEW 2" >result.txt
+ CategoryInfo : InvalidArgument: ( [Select-String], ParameterBindingException
+ FullyQualifiedErrorId : PositionalParameterNotFound,Microsoft.PowerShell.Commands.SelectStringCommand
Posted by: pspad | Date: 2014-09-27 22:11 | IP: IP Logged
Long path must be enclosed to quotas. but its basic knowledge.
"file name"
Posted by: maki | Date: 2014-09-27 22:28 | IP: IP Logged
Only RED (COPY)
I do not know what you're talking about me.
I have no idea about this.
I want to copy all links with the text and do not know how to do it.
Similar Option Other Editor!!! ??? COPY !!!!!!!!!!!!!!!!!!!!!!!!!
EditPad Lite 64 bit
AkelPad 64-bit
EmEditor 64-bit
Edited 1 time(s). Last edit at 2014-09-27 22:28 by maki.
Posted by: maki | Date: 2014-09-27 22:44 | IP: IP Logged
Open ONLY 94,7MB TXT File (WORK)
Sort and Remove Duplicate... (PSPad HANG --NOT WORK !!!) 25 % CPU
Posted by: maki | Date: 2014-09-28 17:20 | IP: IP Logged
No answer/reply hahahahaha ;)
Edited 1 time(s). Last edit at 2014-09-28 17:20 by maki.
