You are here: PSPad forum > English discussion forum > incorrect "save as" path in certain situations
Posted by: Gorlash | Date: 2014-09-24 15:22 | IP: IP Logged
This situation only occurs when loading files from the command line (which is how I always work ); furthermore it only occurs when opening a *new* file, not an existing file.
Say I am in a directory such as c:\home\files and open new file:
pspad new_file.cpp
The actual path and filename for this file are c:\home\files\new_file.cpp
However, pspad does not pick up the current path; it shows the filename (on the title bar) as "new_file.cpp", with no path. Then, when I go to save the file after editing, it opens the Save As dialog, and offers some other path as the destination, rather than my current directory.
This is *very* inconvenient!! It can take quite a bit of clicking to maneuver back to my current directory to save the file...
I would request that when opening a new file, please use the current directory as the base path; also, Save As should not be required, since I already have specified a filename.
I would be *very* grateful if you would consider this!
Posted by: pspad | Date: 2014-09-25 11:34 | IP: IP Logged
Fix will be available in next build
Posted by: Gorlash | Date: 2014-09-25 14:36 | IP: IP Logged
Thank you again, Master!!!!!
Posted by: Gorlash | Date: 2014-09-29 14:41 | IP: IP Logged
is there a development build with this fix, available?
Posted by: pspad | Date: 2014-09-29 15:41 | IP: IP Logged
Not yet, I have to fix several small things yet
Posted by: Gorlash | Date: 2014-09-29 15:53 | IP: IP Logged
Okay, that's cool... take the time you need to get things right!!
