You are here: PSPad forum > English discussion forum > Re: Bookmarks question [Fixed]
Posted by: Gorlash | Date: 2014-09-23 16:55 | IP: IP Logged
The "Create Bookmarks" menu lists special Bookmarks for Bookmark 0 through Bookmark 9; this is nice, because I'm accustomed to those bookmarks from MultiEdit, which I previously used.
However, Control-Shift-0 does *not* create the bookmark, though 1 through 9 work fine.
Is that intentional? I typically start with BM0 when assigning a series of marks, and it is disconcerting for it to not work!!
Posted by: pspad | Date: 2014-09-23 17:14 | IP: IP Logged
Shift+Ctrl+0 creates bookmark for me. If it doesn't work for you, check your running application, if any doesn't have global shortcut registered for Shift+Ctrl+0. Typically Skype, any messenger, graphic card driver...
Posted by: Gorlash | Date: 2014-09-23 18:45 | IP: IP Logged
Oh My... that might well be a challenge... How would I know if some other program is hooking a key??
I looked at Nvidia desktop tools and VirtualBox, the two most likely to do something like that; neither say anything obvious about hotkeys, but that doesn't necessarily mean anything!!
One thing I did is to switch to the desktop and hit Shift-Ctrl-0, and that didn't do anything, which *seems* like that means nobody is looking at that key, but this is a weak assumption...
I'll look around some more.
Later:
I ran Hotkey Explorer (http://hkcmdr.anymania.com/), and it does not show anything registered to Shift-Control-0 (or Shift-Control-AnyNumber).
Edited 1 time(s). Last edit at 2014-09-23 18:52 by Gorlash.
Posted by: Gorlash | Date: 2014-09-23 19:14 | IP: IP Logged
Well, okay, I installed pspad on another machine, and Shift-Ctrl-0 works fine.
So apparently you are right, some other program on this machine is hooking that hotkey, and Hotkey Explorer just cannot see it. Not much we can do about that. Thanks for the suggestion!
Posted by: pspad | Date: 2014-09-23 19:43 | IP: IP Logged
I found this:
wow.couchcomputing.info
Posted by: Gorlash | Date: 2014-09-23 22:01 | IP: IP Logged
HA!!!!!!!!!!!!! Fixed!!!
How did you find that?!?!? I need to make a note of this somewhere so I can find it in the future... wow...
Maybe you can find a place for this in one of your FAQs, as well...
Posted by: pspad | Date: 2014-09-24 04:54 | IP: IP Logged
I look at google for Shift+Ctrl+0
You are right, I will write it to FAQ
Edited 1 time(s). Last edit at 2014-09-24 04:54 by pspad.
