You are here: PSPad forum > English discussion forum > How to save all Paths? (partition letter E-Z)
Posted by: maki | Date: 2014-09-24 15:38 | IP: IP Logged
<-- Not full path!!
And where is full path? !!!!
100% WRONG PATH!!! (SCREEN)
Lost folder or you're really blind?
Edited 4 time(s). Last edit at 2014-09-24 15:45 by maki.
Posted by: pspad | Date: 2014-09-24 15:54 | IP: IP Logged
I have Czech oprating system.
I used DIR *.RAR, Cause I wanted list only rar files into output file. I can use DIR *.* for all files with same result - correct path in output file.
There can be problem with your K: drive (nobody of us doesn't know what file system is on your drive and you as usually don't tell us about it). There can be wrongly configured SAMBA on Linux system what can cause incompatibilities. Or some Novel system what gives to Windows only part of the file name or ....
Do you understand there are missing informations to solve your problem?
Are you understand why it can work for anybody else except you? Cause we are not able to simulate your environment.
Posted by: pspad | Date: 2014-09-24 15:57 | IP: IP Logged
maki:<-- Not full path!!
100% WRONG PATH!!! (SCREEN)Lost folder or you're really blind?
Yes, I am blind, cause file is stored in C:\Temp (you see it in the explorer bar) and in the output file in PSPad is path C:\Temp\
So I don't see any missing part.
Please tell me what is missing.
Posted by: maki | Date: 2014-09-24 16:00 | IP: IP Logged
The operating system does not matter because I wrote 100% correct path.
It's not my fault, that You can not see properly and paths.
Please go back to my previous post and see where you made a mistake.
I repeat again -
Check carefully the previous post #18 !!!
Edited 2 time(s). Last edit at 2014-09-24 16:01 by maki.
Posted by: maki | Date: 2014-09-24 16:06 | IP: IP Logged
post#18
FULL PATH
K:\ALL 2\WWW.DATA.CC_2012年4酒吧流行舞曲资源_C\WWW.data.CC_2012年4月份酒吧流行舞曲资源_C.rar
K:\FOLDER\FOLDER\FILE.rar
\ <- missing
The system can not be named with "\" - so I wrote correctly full path!
and You script - not work full path!
Edited 4 time(s). Last edit at 2014-09-24 16:11 by maki.
Posted by: pspad | Date: 2014-09-24 16:14 | IP: IP Logged
OK. Komplete simulation of your environment, include drive, folders, files.
Are you satisfied now?
Posted by: pspad | Date: 2014-09-24 16:31 | IP: IP Logged
Did you used the /A switch for DIR command as I mentioned in #17?
This will list all files include system hidden e.t.c.
Edited 1 time(s). Last edit at 2014-09-24 16:32 by pspad.
Posted by: maki | Date: 2014-09-24 16:43 | IP: IP Logged
I do not hide any (!) Files in the system - for me it is unnecessary
chcp 65001
dir DRIVE:\*.* /s /b /a >DRIVE:\List3.txt
work fine for me
i want to scan multiple partitions that separate drive letters
OR
OR
OR
" " (empty space)
Edited 5 time(s). Last edit at 2014-09-24 16:45 by maki.
Posted by: pspad | Date: 2014-09-24 16:59 | IP: IP Logged
if you want to list more drives, use my example from the begin and run severals dir commands one by one. For first command use > and for next dir commands >> redirection.
