You are here: PSPad forum > English discussion forum > Re: Future option
Posted by: maki | Date: 2014-09-23 08:32 | IP: IP Logged
Future option:
Similar options in Notepad++
REPLACE
1. Match case (ENABLE / DISABLE)
2. Replace All (no matter up or down)
3. Comparing lists and Remove Repetition (Find differences)
Edited 2 time(s). Last edit at 2014-09-23 08:40 by maki.
Posted by: pspad | Date: 2014-09-23 08:46 | IP: IP Logged
1, 2 - options are in dialog
3 - there are two possibilities
menu Edit / Sort with remove duplicities options
menu Edit / Lines manipulation / Remove duplicate lines
Posted by: maki | Date: 2014-09-23 14:13 | IP: IP Logged
1,2 - What are the options?
3-You can remove duplicates but can not be compared
Posted by: pspad | Date: 2014-09-23 16:34 | IP: IP Logged
Options:
Case sensitive in Options
Entire scope in direction
I don't undestand what do you mean with comparing. PSpad contains text diff capability. Where? Look at help
Posted by: maki | Date: 2014-09-23 17:50 | IP: IP Logged
Comparing list
List1:
1
2
3
4
5
List2:
1
2
3
4
5
6
7
1-click ... Find Differences&remove repetition
Result:
6
7
Posted by: pspad | Date: 2014-09-23 18:17 | IP: IP Logged
Open content of the list 1 in first file
Open content of the list 2 in second file - this tab is active
Right mouse over first tab and choose text diff with this file
Click on the last icon in the top middle of new text diff window and choose missing lines into new file
Posted by: maki | Date: 2014-09-24 09:58 | IP: IP Logged
11485 links - PSPad (bad result)
10515 links - Python script (100% correct result)
Edited 2 time(s). Last edit at 2014-09-24 10:01 by maki.
Posted by: pspad | Date: 2014-09-24 12:08 | IP: IP Logged
Sorry. Another useless reaction from you.
If I write you: PSPad 100% correct and Python wrong result, usability of this answer is same as yours one.
Without any details what do you consider as "good" and as "wrong" I am not able to answer you.
For both of us will be better following:
if you will write any topics and there won't be any answers, it means nobody understood it. In this case try to thing about it, as you are the one who should answer it without knowledge of any background of this question. Write more details.
I won't react to any your questions what can't be answered without asking thousand times for details from you.
Resume:
your question without answers = question that nobody understand it
Edited 1 time(s). Last edit at 2014-09-24 12:49 by pspad.
Posted by: maki | Date: 2014-09-24 13:37 | IP: IP Logged
example links compare&remove repetiotion (PM sent)
Very easy!!!!
list 1 and list 2 (the same links = remove) (understand?)
list 3 (resultat (only new links) (understand?)
Edited 3 time(s). Last edit at 2014-09-24 13:41 by maki.
