You are here: PSPad forum > English discussion forum > Re: How to get back all of prev TABS?
Posted by: maki | Date: 2014-09-22 07:45 | IP: IP Logged
I set up two projects, save!.
Turn on the program. BLANK, nothing.
Posted by: maki | Date: 2014-09-22 07:46 | IP: IP Logged
Save Project /Save Setting. Close program.
Open again PSPad = EMPTY setting, empty tabs, remove project, all empty!
Edited 1 time(s). Last edit at 2014-09-22 07:51 by maki.
Posted by: pspad | Date: 2014-09-22 09:07 | IP: IP Logged
Please screenshot with project you are trying to save
I repeat again. PSPad doesn't delete any files. If you added your files into project and you saved your project, there is file something.PPR
This file you can load anytime. If you close PSPad with loaded project, PSPad will load it next time automatically.
Condition:
1. PSPad isn't installed as portable in Program files folder - settings must be out of program files folder, in default in your profile. See the path in program files / Bankup
2. Save Work/Desktop is enabled in program settings / Files and Dirs
if you want PSPad to open your previously open files when you load project, dont check option "Don't open any file after project load" in project settings
Posted by: pspad | Date: 2014-09-22 11:53 | IP: IP Logged
Sorry, I don't want to see settings, but content of left project panel with files
You have to add files into project!
Edited 3 time(s). Last edit at 2014-09-22 12:00 by pspad.
Posted by: pspad | Date: 2014-09-22 12:23 | IP: IP Logged
OK, Your project is full of files.
When you save it, you can anytime open it again.
Files what be open in time you close PSPad will open again.
What is your problem?
Where do you save project file?
Is there your project file after you save it?
Appears on the bottom of the Project menu (see my screenshots above)?
Posted by: maki | Date: 2014-09-22 12:30 | IP: IP Logged
pspad:Where do you save project file? (partition Y)
Does not appear
Edited 1 time(s). Last edit at 2014-09-22 12:31 by maki.
Posted by: pspad | Date: 2014-09-22 13:21 | IP: IP Logged
maki:Does not appear
Answer #33
check point 1)
Can you tell me what path is in the program settings / Backup (bottom part of the screen)?
